baileychic
Advanced Member level 3
How to design the amplifier circuit?
I have to use INA126 and design an amplifier and for the final output I will use a UG buffer amplifier.
Client's data are these:
I have to apply 5 na current to electrode and record the voltage response
The electrode gives 0.005 to 1 mv depends on material
So, can I use MCP6001 for UG Amplifier?
For HPF what should I choose as cut-off frequency.
Refer attached PDF.
Two electrodes immersed in chemical solution has to be interfaced to the amplifier and further the output of the amplifier will be interfaced to PIC microcontroller for measurement.
Refer attached PDF.
