How to design rail-to-rail input and output bipolar op-amp?
staric
Member level 4
Member level 4
Need to design a rail-to-rail input and output bipolar op-amp. The open loop gain is 120dB. And the fT is 8MHz. I think it is a difficult design. Who can give me some suggestion or reference? Thanks.
One way is to essentially have 2 op-amps in Parallel
I recall doing this in grad school. I don't have my textbook with me.
Doing a Yahoo search on "rail to rail" pnp npn input output yielded this PDF which is a more clever version of what we did: entitled "Low-Distortion High-Speed Rail-to-rail Input/Output Amplifiers" from Analog Devices
If I remember when I get home, I can point you to a specific chapter in a book as well.
Note: You end up having a region with a peak in gm ( transconductance )
Note: I'm unable to link to the Yahoo search page, as well as the PDF in question.
Re: How to design rail-to-rail input and output bipolar op-a
a very good journal
try to get hold of book Analog VLSI: Signal and Information Processing by Ismail and Fiez, McGraw Hill, NY, 1994. Also some of his publication esp ieee jssc vol 31, 1996
hope it helps
karthik
I meant to add
I meant to add, essentially you have 2 "transconductance" opamps, OTA, set up in parallel, an NMOS input and a PMOS input type, with wide swing outputs.
A picture ( difficult to understand in my opinion ) can be found on page 287 of the Johns and Martin book"Analog Integrated Circuit Design" published by Wiley.
