How to design patch antenna with a circular polarization?
dinone
Member level 2
Member level 2
Antenna problem
Hello to all
I have to design a patches antenna with a circular polarizzation @ 5.8 GHZ with about 100 MHz bandwidth. I have no idea how to design this antenna and how dimension the antenna. I have to feed the antenna in a single point. Can someone give me a suggestion or tell me where I can try article and/or book in order to help me? :( :cry:
Regards
Dinone
Re: Antenna problem
If you wanna to make and antenna @5.4GHz, you must considerate its dimenssions in order to achieve the resonate loop. I mean, you must design at dimenssion nearby to carrier wavelength.
In this forum you can find more informations right here:
About dual frequency and dual circularly polarized antenna
McGraw-Hill, Microwave Antenna Theory and Design, Silver S
Re: Antenna problem
dinone said:
Hello to all
Regards
Dinone
Dear dinone,
u should read antenna microstrip antenna books, specially "Microstrip Antenna Design Hanbook" by garg, bhartia, bahl and Ittipiboon. there is a lot of patch shapes and configurations available for you, specially becouse of your narrow-band application. if you can use probe, u should try diagonal fed square patch, or u can use notched circular patch, wich has a wider bandwidth.
byheway, i found a special paper for you, an aperture coupled circular notched patc h, with more than 7% CP bandwidth, and a gain of about 10dBi in 5.7 GHz, i think author designed it for ya! cheers!
marti
Antenna problem
Hi Dinone,
You might wish to have a look at a book titled "Antenna Theory analysis and design". It might give you a solution.
Re: Antenna problem
Hi dinone
I have here examples of microstrip printed antennas "considerations for GPS antenna for automotive applications"
scale it to your freq.
PL
Re: Antenna problem
Hi to all
I know the book
"McGraw-Hill, Microwave Antenna Theory and Design, Silver S"
It is a good book in order to understand antenna, but it doesn't speak about printed antenna: could someone tell me where I can study about this type of antenna (if there is books or application notes)?
:( :cry:
Antenna problem
Good books about the microstrip antennas:
1. R. Garg et al., "Microstrip antenna design handbook", Artech House 2001
2. Compact and Broadband Microstrip Antennas. Kin-Lu Wong Copyright 2002 John Wiley & Sons, Inc.
also many information You can find in Balanis book.
Best regards,
Kit-the-great
Re: Antenna problem
I know that the Pozar books are very good about this type of antenna: someone can give me one of this? :( :cry:
Regards to all
Re: Antenna problem
Hi dinone
here the second book I hope it can help you.
regards
PL
