T
treez
As you know, all switch mode mains LED light bulbs need protection from the overvoltages that may occur if they are accidentally connected to a triac dimmer.
Given that such circuits are usually dissipative dampers, would it be acceptable, as an alternative, to simply sense the DC bus voltage with a potential divider, and if it gets too great, then an in-line fet can switch out the front end from the primary DC bus?
(ie instead of using a dissipative RC damper)
