how to design custom board
kabaleevisu
Advanced Member level 2
Chennai,India
hi all
i like to design custom board here i attached . is it possible to design board in mechanical symbol or is it possible to import in .dxf file
NOTE:
i have not auto cad to import .dxf file. I LIKE TO DESIGN THE BOARD IN MECHANICAL SYMBOL IS IT POSSIBLE
:x
I'm not sure what you are asking, but in general every pcb needs a board outline.
A mechanical part outline is not recognized as a board outline so you need to copy/import the outline.
In this case I would use a DXf file to import the outline into the software. This is the most easy way.
If you do not have a DXF you can place the mechanical part on you'r board and then draw the board outline.
Remember, you are placing parts on a pcb, not a pcb on a part.
