How to design an wideband(0.95~2.15GHz) LNA with 15dB gain?
Calvinckc
Newbie level 6
Newbie level 6
is it suitable to choose the center frequency(1.55GHz) to design the LNA ??
Is it a MMIC or HMIC?
Re: How to design an wideband(0.95~2.15GHz) LNA with 15dB g
As a start. But you cannot use simple matching circuits since they will not be broad band enough. You can use mult-stage matching to lower the Q of the network and broaden the match. Or a more elegant solution is to use feedback in the LNA to set the input impedance so that the input to the LNA is already 75 ohms without any matching.
