How to design a power on reset block and generate a delay?
naisare
Member level 2
Member level 2
I need to design POR block which can give immunity to glitch in the power supply.
The requirement is any power supply glitch which losts less than 1us shouldnot trigger the reset pulse. but if the glitch losts for more than 10us then rest pulse should be given..
What is the schematic for this kind of requirement.. How to avoid the big capacitor required to generate the delay..
thanx a lot
Re: power on reset block
You can copy circuit from original designs.
Find DS1232 in Maxim web site. Then download data sheet with DS1232 equivalent schematic.
DrWho
yea.. how to generate a delay of around 5usec without using high capacitor( not more than 20pF).
I used the Inverter fallowed by Capacitor and a schmitt triger to generate the delay.. but the capacitor was very high.. Is there any other method.. or what is wrong in my simulation..
why not use a counter(50) for the delay about 100n or so?
naisare,
if you understand chinese,
see here:
Added after 1 minutes:
Also ,there are some papers for por design,you can search on IEEE.
