How to design a PLL according to specs?
hanjiemy
Member level 2
Member level 2
Hi all,
I want to design a type-2 pll which consists of PFD(general), Charge Pump, passive LPF (2order), LC tank VCO, Feedback Divider N.
I know Icp=50uA, vco gain=40MHz/v, vco output frequency range is 150MHz-220MHz, Z(LFP)=(1+sRC2)/(C1+C2)s(1+sRC1C2/(C1+C2))), then R=10k C1=10nF, C2=39nF.
I calculate: t1=79.6us; t2=390us;and
Loop BW is 904Hz, is right? and Phase Margin???
thank u very much!
use matlab for system simulation (S-Domain) to check stability of the loop first, then u can use matlab for transient sim. of the loop with swiching nature of Phase-detector considered.
NOTE: do not simulate pll with spice before system simulation or u will waste your time!
BEST!
if you have cadence run a behavioural simulation first using the verilog a blocks and you can simulate the PLL quickly, better set up then matlab and very fast
if you have cadence
