how to design a low gain and low bandwidth op?
jfyan
Full Member level 2
shanghai,china
hi all,
i need an op-amp with low gain (about 10=20db) and the low dominate pole ( about 10khz), so could you suggest me some good topology or references.
thanks.
jeff
hi!
I think you can use single stage diferential amplifier that normally will give you ard 20 -30 dB and with only 1 dominant pole and you can adjust the pole frequency by putting capacitor at the output.
    jfyan
See fig.9.43b and 4.33 in Razavi's book
    jfyan
Bias your transistors in weak inversion and fix the gain by connecting to the output node a matched gm to increase the output conductance.
Does transistors in weak inversion hurt noise performance.
A high gain and high bandwidth opamps is hard to design. Low gain, low bandwidth one is much easier. Using capacitor to control bandwidth, transconductance (Id or/and W/L) to control gain.
jfyan said:
hi all,
thanks.
jeff
