HOW TO DESIGN A COMPUTER BASED VOLTMETER
cutytongy
Newbie level 2
Newbie level 2
computer voltmeter
PLEASE CAN ANYONE HELP ME ON HOW TO DESIGN A COMPUTER BASED VOLTMETER TO READ IN AC AND DC VOLTAGES FROM ITS SERIES OR PARALLEL PORTS AND DISPLAY THE READINGS ON THE MONITOR USING PASCAL LANGUAGE
pc voltmeter
use one ADC to get the voltage to the parallel port
adc0804 the one i used
for help it in C language for parallel port get e-books from
www.bibinjohn.tk
parallel port voltmeter
Well my idea is a bit different. I would use PC sound card for it. If 555 timer is used as voltage controlled oscillator then the pulse width of the output waveform can be detected using some programming. I haven't implemented it yet but may be a precise solution.
computer volt meter
You may find many ideas in the following link:
pc based voltmeter
The best option is to use the Parallel port of the PC to connect with an ADC...
Use some fast switching ADCs..
sound card voltmeter
Another idea is to use Microsoft text to speech engine so that the sofware speaks aloud the reading once it gets steady. In this way, it would be convenient to take readings without looking into the monitor.
voltmeter computer
You can also use the Game Port of the sound card, not accurate, but a readily available ADC with two channels :)
You have to convert the voltage into current for game port, search the web and you will find a lot of interfacing examples.
PS: It will not be interrupt driven, you have to poll.
