how to desgin a phase shifter in base band?
kokikak2
Newbie level 1
Newbie level 1
I want to design a phase shifter operating in the range of frequency between 10 KHZ -to- 1 MHz.
pleaze i need your replies as fast as possible.
thanks in advance.
yasser samir
kokikak2,
You may need to design a all pass filter for this application. Delay time will be a constant but shifted phase will be depand on frequency.
No matter you design a circuit to shift phase of tone. But it's nearly improsible to shift a board band analog signal in a same vaule of phase.
If the boardband signal be modulated by another signal then it's a different story...
Regards,
Wenye
Dear kokikak2
What is the phase shifter ?
Can you explain that?
