How to derive the factorial of (1/2) ?
amriths04
Full Member level 5
Full Member level 5
i know that (1/2)! = 0.5*√pi
but i want to know how that value was got (gamma functions? if so how)?
Re: factorial of (1/2)
Yes the value comes from the gamma function.
The factorial n! coincides with the gamma function at positive integer values. So if one equates the factorial function on all positive reals with the gamma function, then one can say that
(1/2)! = sqrt(pi)/2
even though the factorial function was originally only defined for the natural numbers.
Added after 14 minutes:
Noooo I'am wrong. It's Gamma(n+1) = n! and one does not equate the factorial with the gamma function. Sorry.
Added after 26 minutes:
The general definition of a factorial is
x! = Gamma(x+1)
By a little integration you can prove that
Gamma(1/2) = sqrt(pi)
Gamma(x) = (x-1) Gamma(x-1)
So the idea seems to be that
(1/2)! = Gamma(3/2) = 1/2 * Gamma(1/2)
yes, i am aware that Gamma(1/2) = sqrt(pi).
but i want to prove the above mathematically.
that is how ∫(t^-0.5)*(e^-t)dt between 0 and inf = sqrt(pi) ??
Damn. This is how it goes. Just calculate
Gamma(3/2)
by integrating and then just use the general definition
x! = Gamma(x+1)
for all real x.
Added after 8 minutes:
I see. hmm.
Added after 25 minutes:
Can't say that I see how to do the integral by just looking at it. But you can see how the integral comes
from a property of the Gamma function called the 'Euler reflection formula':
G(x)G(x-1) = pi / sin(pi*x)
by pluging in x=1/2.
factorial of (1/2)
change the variable x=z^2.
obtain the new integral and define it i.
calculate i^2 . so it will a double integral
change the variables of double integral from Cartesian to polar.
calculate i^2 . it will be pi.
now i=sqrt(pi)
    amriths04
now i=sqrt(pi)
Yes check out
https://en.wikipedia.org/wiki/Gaussian_integral
there you find how it's done.
