yw21century
Newbie
Hi, guys
We are designing an ASIC chip based on TSMC 40 technology. The nominal voltage is 1.1v (VDD) and the maximum clock frequency is 500MHz. We define static IR drop criteria as no more than VDD*5% (including VDD and VSS) and dynamic IR drop criteria as no more than VDD*15% (including VDD andVSS)
Now we are defining supply voltage level of our chip. Which criteria should we use to calculate minimum supply voltage level in order that junction voltage not less than foundry requirement, say, VDD*(1-10%)? I meant, should I use VDD*(1-10%)+VDD*5% or use VDD*(1-10%)+VDD*15% as minimum supply voltage of our chip?
Appreciate if you can give some elaboration!
Bruce
Bruce
