HOW TO DEFINE SHORT CUT KEYS IN ALLEGRO
v_kumar
Full Member level 5
Full Member level 5
India
HELP
CAN ANYONE TELL ME HOW TO DEFINE THE SHORT CUT KEYS IN ALLEGRO.
THANKS
hi
check for pcbenv directory and file env
edit env file and do the following
eg;
alias F4 "delete"
alias p "place manual refdes"
alias ~L "redisplay"
# ~ for control
or
open allegor pcb editor
on allegro command line do the follwing
--TuX
how to remove the assigned keys
and how to assign for swaping layers top and bottom.
the option for it is present while routing right click-->swap layers
delete the env file present inside the pcbebv folder. This remoes all customer settings and retains allegro default.
On keyboard use + and - sign (present at the right side of the keyboard along with numbers) for changing the layers.
Good Luck!
Nagaraj.
    v_kumar
thanks dear tux;
but i try that u called but i dont fine any change Plz againe and give more details in the process.
Best Regards
Hi Antonios
can u explain me what u did.. so that i can try to help you out..
--TuX
Hi tux
i need HOW TO DEFINE THE SHORT CUT KEYS IN ALLEGRO
i need to press short cut key insted of select the command from menu
as Zoom fit F9
Zoom in F10
and so on i need to make my short cut key.
i am giving the format try this
if u want m letter for move then
u have type like this funckey m move
STATEMENT is funckey (ur shortcut letter) (and the instruction u want)
ex:- funckey m move
ranga
Added after 1 minutes:
for removing this shortcuts if u reopen the file u will lost all of the shortcuts
