How to define global variable in verilog?
saurabhs
Varanasi
Hi all
I wanna define global variable in verilog so that i can use them in different module.
How it can be done.
Thanks in advance.
Re: Global Variable in Verilog
With verilog, pretty much everything's "global". You can use hierarchical reference to access any variable in any module.
For example:
module glb_var_mod; // define all global vars in this module
reg glb_x = 1'b1;
endmodule
module dut;
glb_var_mod.glb_x = 1'b0; // change value of a global var
endmodule
- Hung
For example:
reg glb_x = 1'b1;
endmodule
module dut;
endmodule
- Hung
Very insightful indeed. Thanks!!
Curious to know can we do the same in VHDL too?
For example:
reg glb_x = 1'b1;
endmodule
module dut;
endmodule
- Hung
i did so but this error was the result:
Error :(on line 7 ) : near "=": syntax error, unexpected '=', expecting IDENTIFIER or TYPE_IDENTIFIER
what is this?
i did something like this another time on another project , and there was an error "Undersolved reference to 'glb_var_mod"
and what is this?!
Hi
Maybe you got this error because you didn't use 'always' or 'initial' blocks. Assigning values to reg must be in one of these blocks depending on situation.
For example:
initial
reg glb_x = 1'b1;
endmodule
Just a note that global variables are not synthesizable, and in general, not a good programming practice in any language.
If instead you really need a global value, use a `define in Verilog or a parameter declared in a package in SystemVerilog.
