How to define dB and how does it refer to power values?
saif haider
Full Member level 1
Full Member level 1
Pakistan
what dB shows us about the values on power how can i define dB
Re: dB
a Decibel or dB is used for the logarithmic scale.
Sometimes,when we plot graphs,the range over whicha particular quantity should be plotted is very large.Say fro eg frequecy.u may not be able to plot frequencies ranging from Hz to GHz on the same graph.for this reason, we use a compressed scale,ie the logarithmic scale.
Re: dB
dB = 10*Log(Power/1W)
It shows how much power is below or above 1W. If power output is 1W, then it is 0 dB. If you double it, 2W means 3dB. dB makes the calculations easy because we don't multiply/divide the values, but we add or subtract dB values.
Re: dB
10log(P(u want)/P(any reference))
