how to define a port in IE3D ?
sahar20
Member level 1
Member level 1
How can i calculate the S parameters in case of reflection of a vertical planewave on a patch antenna. how to define a port in IE3D ?
There is no s-paramaters involved if you need to include plane wave. On IE3D and FIDELITY, you can define N-ports and planewave excitation with both E and H-polarizations simultaneously. After simulation, you will get the N-port s-parameters. Besides, you will get a general pattern. From the general pattern, you can define a polarization of planewave (any combination of E and H or even circular pol), and you can find the V and I on the ports. It can't be done on MGRID in post processing mode or PATTERNVIEW.
    sahar20
I want to append one relative question here. It seems there is possibility we need to write self-defined equations to extract those V and I. However, in my opinion, user-defined equations can not be added in IE3D, right?
