Eduardo Luis
Newbie level 3
Please, I have a transformer with a 10V x 100mA secondary. I plan to power an MCU based project with it, but my problem is: 10V is much more volts than I need, I plan to power my circuit with 3.3V at most. And 100mA of current is too low, I need more.
So I'm wondering: is there a way to reduce the volts to 3.3V, and increase the current capabitity to, say, 300mA? Since the total power would be the same (10V x 0.1A = 1W and 3.3V x 0.3A = 1W), I think it's possible.
I would also need to make this using only electronic components, and not with another transformer, because that would be pointless.
I know it's possible to use an oscillator to build a circuit that will increase voltage and reduce current, but is it possible to use the same approach to do the inverse, reducing voltage and increasing current capability?
Thanks in advance for any help!
Eduardo
Eduardo
