How to declare hex data to the MsComm & check received b
cwt
Member level 5
Member level 5
MsComm Control
Hi out there..
I have encounter some problem when dealing with MsComm Control.
Let say, i want to sent out &H11 (hex), which is 00010001 binary, how am i going to send that outwards through serial port? :(
I am using 8LEDs to test the out coming bytes. If the circuit encounter 00010001, it will light up accordingly.
The problem is, if i declare the hex data to the MsComm, there will be an error. So how am i going to declare the hex data and make sure that the receive bytes are correct?
Please help. :cry:
Re: MsComm Control
Try using the Chr() function,
ex.
I want to send 0x11 = d 17:
I write "MsComm1.Output = Chr(17)"
If it works you can easily create a function that converts hex to dec.
bye wn.
MsComm Control
Is there any method left?
Because..i already create the database in hex.
And that database is very long..
MsComm Control
Its ok..i have finish the convertion..phew~damn tired..haha..thanks!
