sakshi gupta
Full Member level 1
on what basis we can decide ,we have to use fifo or Hanshake technique for data transfer between async clock domains ?
sakshi gupta said:on what basis we can decide ,we have to use fifo or Hanshake technique for data transfer between async clock domains ?
sakshi gupta said:If I need to transfer data from one clock domain to other ,on what basis I will decide which synchronisation techique I should use to avoid metastability . What will be factors on basis of which I decide to choose FIFO or Handshake technique ?
Hope my query is clear now .
rakko said:In cases where the sender and receiver clocks are the same but there is a skew between them, then you can use a double flop synchronizer to handshake the data accross the clock domains.
