How to debug the problem of Error using ==> fscanf invalid size
AILab
Newbie level 5
Newbie level 5
Currently i am doing the feature extraction using matlab, but i face the problem of error using==>fscanf invalid size, but i check so many times there is nothing wrong the coding part. Anyone have suggestion please?Thanks
If you can post your Code ,it Will be easier to point out the mistake
here is an example that will produce "fscanf invalid Size Error"
%example
clc
fidw=fopen('sample_record.txt','W');%Open a sample file to  Write
rad=[ 1 2 3 4 5 6 7 8 9 10];
uint8(rad);
% for i=1:10
    fprintf(fidw,'%d \n',rad(1,i)); %Write some data
% end
fclose(fidw); %close File
fidr=fopen('sample_record.txt','r');%Open File Again to  read
A=fscanf(fidr,'%d',[COLOR="#B22222"][B][inf 1][/B][/COLOR])
status=fclose(fidr);%close Fil
, matlab Warns !
??? Error using ==> fscanf
Invalid size.
Error in ==> seek_example at 15
A=fscanf(fidr,'%d',[inf 1])[/COLOR]
so check the size specified in the fscanf,it might be wrong .
