How to cut the copper clad plate?
xmli1976
Full Member level 1
Full Member level 1
cutting copper clad
I've used a angle grinder, but it's too rough.
how to cut coper lad
dremel
    xmli1976
how to cut copper
Hi
If you are using a dremel or similar please do ot forget to use dustmask. The glassfiber particles can be irritating.
I use a "bench metal scissor"
Cl
    xmli1976
how to cut copper clad boards
If you want to cut a clad piece of material a bench shear is good but leaves a rough edge - tin snips work well for thin material, for odd shaped pieces a dremel tool, router or nibbling tool may be used.
SiGiNT
    xmli1976
