How to create archs in traces with Allegro?
layout guy
Newbie level 5
Newbie level 5
Can anyone tell me how to create archs in traces with Allegro? Instead of doing angular mitering in traces I want to arch them.
Thanks
Layout Guy
Re: Archs in Allegro
click f6 or add connect icon.... from the control panel select the option tab
and change the line lock option to arc and if required you can change the angle too.
regards
Neena
Thanks Neena!
Yup, that function is good for the arching while routing.
I am looking for a way to convert already routed and length matched bunch of traces/pairs to archs at the corners, while keeping the same separations, spacing etc.
Layout guy
Use Slide command and again in control menu select Arc.
Regards,
M
