How to create an embedded floppy drive using SD card.
Magnatron
Full Member level 2
Full Member level 2
Deolali
hey,
I need some inputs in creating a "virtual hardware" FDD drive using some SD card and a PIC micro controller.I have a PIC18f4550 with me and i know it has sufficient RAM for the SD interface? then how do I confuse the windows to have a FDD present in its hardware.. 1.44 MiB is enough for me. any help? asd.jpg
hey,
It appears you want to create a PIC based SD Card Reader/Writer with USB interface:
Some examples:
SD Memory Card Interface - Strictly Serial Interface Nonbootable
Implementing FAT on CompactFlash cards, SD/MMC cards and USB sticks
You will have to implement a FAT File System Read capability with the PIC, a SPI interface with the SD card and the appropriate USB interface for the PC to be able to boot successfully.
You will most likely have to settle for a larger "floppy" size 256MB, 512MB or larger. Unless you want to create a smaller partition.
The first example is a fairly good example of a PIC based bootable SD card reader.
BigDog
Thx Mr
I was looking for this since a long time ago
if u have an idea to use the same schematic but with usb flash instead of mmc card
ur help is appriciated
thx
Johnny
