i'm not sure how u can generate a 36-bit random value. $random provides only 32 bit max value. what you could probably do is, concatenate it with a 4-bit counter
use $random%(see_d) function
it will generate values betwwen -(see_d-1) to +(see_d -1)
To constraint to +ve values only
use {$random}%(see_d) so the values generated will be in the range 0 to (se_d -1)
