how to convert the Spectre results into .ps or .pdf format
faiq khalid lodhi
Newbie level 6
Newbie level 6
Pakistan
Hi every one.
i would like to save the Cadence Spectre results into high resolution format. Can anyone give me any idea.
Instead of printing to a printer, you can print to a .ps file.
Can you please tell me the procedure to print the file into .ps format.
i have tried but i was unable to print it into the .ps file and got the following errors./
"Plotter in not mentioned"...................... i have tried to select the plotter but it has not any options.
"Page size is not set"............................. here i have also the same problem.
Can you please provide me the material that is helpful for this....
Thankx a lot.
Hi faiq Khalid,
I was also facing same problem.I suggest you to create service request in the online support of CADENCE. You need to do some changes in the .cdsplotinit file to be able to get the plotter name and size of A4.
Then i am sure you can print it to .ps file
hope this helps you .
