Is there a theory that can be directly apply?i think the theory used here is that parallel identical voltage sources produce the same output voltage each source produce.
Without the voltage sources,the two are exactly the same.you can try placing a short on the two + terminals of the sources. you will see that the two circuits are eqivalent.
try examining both terminals of each component, find to which component they are connected to.
When performing network reduction for a Thévenin or Norton model, note that:
- nodes with zero voltage difference may be short-circuited with no effect on the network current distribution,
- branches carrying zero current may be open-circuited with no effect on the network voltage distribution.
