voon
Newbie level 2
![Newbie level 2](/styles/images/ranks/alevel2.gif)
hi, there...i doing & rushing my final year project...i need to know how to convert rgb image to grayscale image in c++ MFC...below is my code...but..it can't work...why leh...tis code is in a button called Normalization...after the image display the image will be change to grayscale after i click the Normalization button...the load & display image i already done...so...it just the convert color haven't fix...so...can you help me to modify my code for grayscale...thanks a lot for helping me & replying..hope hear from you soon...if can't see my codes below..then..pls download the zip file i sent...tis zip file is my c++ MFC program...thanks...
void CFingerprintSystem_FASSDlg::OnNormalization()
// TODO: Add your control notification handler code here
CString m_sBitmap;
HBITMAP hGrayBitmap = (HBITMAP) ::LoadImage(AfxGetInstanceHandle(),
m_sBitmap, IMAGE_BITMAP, 100,140, LR_LOADFROMFILE |
LR_CREATEDIBSECTION);
BITMAP bm;
GetObject(hGrayBitmap, sizeof(BITMAP), (LPSTR)&bm);
typedef struct tagBITMAP
LONG bmType;
LONG bmWidth;
LONG bmHeight;
LONG bmWidthBytes;
WORD bmPlanes;
WORD bmBitsPixel;
LPVOID bmBits;
BITMAP, *PBITMAP;
if (hGrayBitmap)
CStatic *pImg = (CStatic*)GetDlgItem(IDC_STATIC_Processed);
BYTE * pImgByte = (BYTE *) bm.bmBits;
if(pImg==NULL)
AfxMessageBox("Fail to convert grayscale");
else
INT iWidthBytes = bm.bmWidth * 3;
for ( int y = 0; y < bm.bmHeight; y++)
for ( int x = 0; x < bm.bmWidth*3; x++)
unsigned char R = pImgByte[y*iWidthBytes+x+2];
unsigned char G = pImgByte[y*iWidthBytes+x+1];
unsigned char B = pImgByte[y*iWidthBytes+x];;
INT gray = ceil(0.3*R + 0.59*G + 0.11*B);
pImgByte[y*iWidthBytes+x+2] = gray;
pImgByte[y*iWidthBytes+x+1] = gray;
pImgByte[y*iWidthBytes+x] = gray;
pImg->SetBitmap(hGrayBitmap);
CString m_sBitmap;
BITMAP bm;
LONG bmType;
LONG bmWidth;
LONG bmHeight;
LONG bmWidthBytes;
WORD bmPlanes;
WORD bmBitsPixel;
LPVOID bmBits;
BITMAP, *PBITMAP;
if (hGrayBitmap)
if(pImg==NULL)
else
