How to convert Matlab code to VHDL code?
sedighe
Junior Member level 2
hi friends
can anyone tell me how i can change "matlab code"s to "VHDL code"s?
be happy & thanks
Re: matlab code to VHDL
u can convert only filters in to VHDL (from matlab format )in matlab software. if u want to convert the matlab code to vhdl or verilog code then u have to install Xilinx accel dsp. which u may get a trail version for 30 days and try on it first.
then go for licenced version. from www.xilinx.com
    sedighe
matlab code to VHDL
Could you generate VHDL form Simulink? Wich Blocks are working? How bugged it is?
I once generated C code form Simulink to run on a microcontroller, it worked very well for DSP and finite state machine.
what algortihm you have to change, then according to that you can change
sysvu, dsp builder,sys gen ext
are there
