niz_se
Junior Member level 1
Hi!
I´m in need to design a voltage reference to be used with an A/D converter (10bit). I need the reference to be 2.048V
I´m designing a 5V system.
So, I was looking at the LM385 because the referensce design looked simple but I do not know how to convert it from 9V to 5V system (if possible).
Later, because of the need of greater Temp. range I wanted to use the TS431 but the reference design for that one made a "brain fuse" burn...
Can anyone please help me out here?
Documentations for these devises can be found here:
LM385:
https://www.elfa.se/pdf/73/733/07338502.pdf
TS431:
https://www.elfa.se/pdf/73/730/07305345.pdf
Thanx! :?
LM385:
TS431:
Thanx! :?
