How to convert from IM3 to IP3?
Superowl
Junior Member level 2
What is the relation between IM3 (3rd order intermodulation component) and IP3 (third-order intercept point)? How do I convert from IM3 to IP3?
iip3 im3
Third order Intermodulation product (IM3) is an in band spurious frequnecy component which degrades the sensitivity of the desired signal. IIP3 point is a measurement to determine the severity of this effect hence the linearity of the system. The intercept point is when the fundamental component sweep intersects with the third order component sweep. Hope this helps
Rgds
oip3 im3
IP3 = SCL + | 3OIM / 2 |
Where SCL is the Single Carrier Level (dBm)
3OIM is the relative level of the Third Order Intermodulation Product (dBc).
Be sure it is tested in linear range.
what is im3
There is a nice paper describing what do you want to know from Prof. Willy Sansen, "Distortion in Elementary Transistor Circuits", IEEE TCAS2, vol. 46., no. 3, Mar. 1999.
From this paper we can see that, for small signal, weakly nonlinear system and first order approximation, IM2 = 2HD2 and IM3 = 3HD3.
As well as IP3 = Vin/sqrt(IM3) or (IP3)dB = (Vin)dB - (IM3)dB/2
Obviously, the small IM3, the larger in value of IP3.
