Munaaf.M.A
Newbie level 1
I need to convert double end of Fully differential opamp to single ended as i need only one output pin in order to design a filter. I have used VCVS but that is not a correct procedure as we dont get layout of VCVS. so i need suggestions for the above question. Thanking You. Waiting for a quick response. in CADENCE virtuoso environment
