[SOLVED] How to convert CMRR in DB to Numerical Value
satiz
Member level 5
Member level 5
My CMRR value is 90dB. Can anyone explain to convert this in numerical value.
90 dB = 20 * log(voltage_ratio)
voltage_ratio = 10^(90/20) = 31623
The output will change max 1/31623 of the input common mode change. In this case about 32uV/V
You can also get this directly by going from out/in = -90 dB = 10^(-90/20) = 32u
What about doing an internet search on your own: "online dB calculator"...
Klaus
Online calculator gives me the results. But Mr.std_match explanation is very much useful to understanding better way :)
