[SOLVED] how to convert Array[10] into Long in MikroC Pro
buddhikaneel
Member level 1
Member level 1
Hi.
int xArray[10];
long xNo;
I want to convert xarray into xNo. How can i do it
xArray[0]=1;
xArray[1]=2;
xArray[2]=3;
xArray[3]=4;
xArray[4]=5;
xArray[5]=6;
xArray[6]=7;
xArray[7]=8;
xArray[8]=9;
xArray[9]=0;
result could be
xNo=1234567890;
____________________________________
Can you tell me is there another way to do this.
I will reading Keypad Keypress into that array. Finally i want to 10 Digit long data from which is last pressed 10 keypad strocks.
what can i do..?
is the content of the array 1,2,3,4,5.... or '1','2','3'... because in the second case the ASCII characters actually represent 0x31.0x32,0x33...
Alex
the simplest way I can think of is
unsigned long xNO;
xNO=xArray[0]*1000000000+xArray[1]*100000000+xArray[2]*10000000+xArray[3]*1000000+xArray[4]*100000+xArray[5]*10000+xArray[6]*1000+xArray[7]*100+xArray[8]*10+xArray[9];
I also think about that. But i don't know there are any functions in mikroc pro to do that. how ever i'll use this method for now.
Thanks for help..
actually there is a function named atol, it is included in stdlib.h, check if your IDE has it but note that you have to include the library which will take more space that using the custom function of the previous post.
Alex
---------- Post added at 16:28 ---------- Previous post was at 16:15 ----------
Just a note, atol works by converting the characters '1','2','3' so you have to convert 1,2,3 to 0x31,0x32,0x33... you can easily do it using (value+0x30) or you can assign directly 0x30 to 0x39 instead of 0x0 to 0x9 when the keyboard button is pressed.
hi
what if its a string?
like this
str1[]='a';
str2[]='b';
str3[]='c';
str4[]='d';
str5[]='e';
str6[]='f';
str7[]='g';
str8[]='h';
str9[]='i';
str10[]='j';
result could be
message[]="abcdefghij";
copy the letters one by one to the message string
Reactions: tonete
    tonete
that does mean a is index 0, b is in index 1, c is in index 2, and so on...?
or i will hav to use strcpy?
sorry..im not expert
Re: how to convert strings with one letter into one word
You can use string concatenation like
message = str1 + str2 + str3 + str0;
Reactions: tonete
    tonete
by the way...its for my mikroc code
The simplest way is
message[0]=str1[0];
message[1]=str2[0];
message[2]=str3[0];
message[3]=str4[0];
message[4]=str5[0];
message[5]=str6[0];
message[6]=str7[0];
message[7]=str8[0];
message[8]=str9[0];
message[9]=str10[0];
I'm not sure why you have specified arrays to hold one charter in each one, why not simple variables?
individual array for single character storage is not an efficient way...
this may help you. i am not sure ! :-?
unsigned char *ptr[10];
ptr[1]=str1[0];
ptr[9]=str10[0];
i=0;
while(i<9)
message[i]=*ptr[i++];
Reactions: tonete
    tonete
This is embedded C , there are no strings like the ones you describe, these are arrays and the concatenation will not work
ptr[1]=str1[0];
ptr[9]=str10[0];
i=0;
while(i<9)
The first member of the array is ptr[0], not ptr[1]
To assign the address of an array member to a pointer you have to do one of the following
ptr[0]=[COLOR="#FF0000"]&[/COLOR]str1[0];
ptr[0]=str1; // the same as &str1[0]
Alex
ptr[1] is my mistake ptr[0] is correct.
Reactions: tonete
    tonete
&str1[0] is the address of member 0
str1[0] is the content of member 0
these are not equal or interchangeable
sorry for the inconvenience
your are right.
&str1[0] = str1 = &str1
Reactions: tonete
    tonete
if its something like this?
unsigned char getKeyboard(){
do {
if (Ps2_Key_Read(&keydata, &special, &down)) {
if (down && !special && keydata) {
   if(keydata==97){kb=97;}  //a
   if(keydata==98){kb=98;}  //b
   if(keydata==99){kb=99;}  //c
   if(keydata==100){kb=100;} //d
   if(keydata==101){kb=101;} //e
   if(keydata==102){kb=102;} //f
   if(keydata==103){kb=103;} //g
   if(keydata==104){kb=104;} //h
   if(keydata==105){kb=105;} //i
   if(keydata==106){kb=106;} //j
   if(keydata==107){kb=107;} //k
   if(keydata==108){kb=108;} //l
   if(keydata==109){kb=109;} //m
   if(keydata==110){kb=110;} //n
   if(keydata==111){kb=111;} //o
   if(keydata==112){kb=112;} //p
   if(keydata==113){kb=113;} //q
   if(keydata==114){kb=114;} //r
   if(keydata==115){kb=115;} //s
   if(keydata==116){kb=116;} //t
   if(keydata==117){kb=117;} //u
   if(keydata==118){kb=118;} //v
   if(keydata==119){kb=119;} //w
   if(keydata==120){kb=120;} //x
   if(keydata==121){kb=121;} //y
   if(keydata==122){kb=122;} //z
   } } Delay_ms(5);
return kb;
} while (1);
interfacing keyboard...
when i press the a key in the keyboard..the value is being return in kb..the next press will be added to the ist one and so on
after i press enter..that will be the time it displays the word in the lcd
if (down && (keydata==13)){ break;}     // enter
example
first press ---- h
2nd ---- e
3rd ---- l
4th ---- l
5th ---- o
result would be "hello"
thank you
(mikroC for PIC is used for coding)
You may try this:
#define MAX 100	// maximum number of letters the array will hold
int main()
	unsigned char letter;	// uchar to hold the current letter
	unsigned char letterArray[MAX];	// array to hold the string
	int index= 0;	// start with 0 index
	while(1) {
		letter= getKeyboard();	// get letter
		if(letter!= 13)
			letterArray[index++]= letter;	// insert next char
		else {
			letterArray[index]= '\0';	// terminate current string
			// lcd printing code here to print 'letterArray'
			index= 0;	// reset index to start again
Reactions: tonete
    tonete
