Traditionally, rotating frequency converters (motor-generator combinations) have been used.
Today, you can buy static converters for this purpose. This are essentially frequency inverters as used for VFD (variable frequency drive) applications with suitable switching frequency filtering at the output. Additional transformers may be used for voltage conversion.
Dear munzir
Hi
How much is the power that you need ? however it is possible , with a simple SPWM , and some other methods. ( it is simple ) .
Best Wishes
Goldsmith
