tony_lth
Advanced Member level 5
I have a 10M sinwave signal, and I want it to be divided-by-4 with HMC365. for sinwave, the minimum input freq is 200M, but for square wave, the HMC365 can operate to DC. So I have to convert 10M sinwave to square wave.
The 10M sinwave phase noise is -140dBc/Hz@1KHz, and HMC365 noise floor is -135dBc/Hz@1KHz. HMC365 use flip-flop tech, frankly I don't know it at all.
So I need one IC convert 10M sinwave to square wave, make it divided-by-4 with HMC365, then convert 2.5M square wave to sinwave, the 2.5M sinwave should have phase noise better than -135dBc/Hz@1KHz.
Anyone can recommend the IC for me?:???:
HMC365 use InGaP GaAs HBT technology, so I guess the IC using this tech should meet the PN requirement.
