yyan71
Banned
- Joined
- Sep 24, 2009
- Messages
- 28
- Helped
- 4
- Reputation
- 8
- Reaction score
- 4
- Trophy points
- 1,283
- Location
- Australia
- Activity points
- 0
Hi there,
I am designing a device which is planning to transmit a ECG signal from a portable device to remote base station.
Now ECG front end circuit has been down and I can obtain the normal ECG signal under 150Hz.
Now I am not very sure how to convert the low frequency from under 150Hz to intermediate frequency (like 100MHz to 850MHz). The reason I need IF is that I will use a LO and Mixer to up-converting the signal to RF later.
I have two ideas:
1. Find a AM/FM modulator to modulate the signal and convert the signal frequency to IF (like 100MHz to 850MHz). Now I am using AD630, but this one can only give me a fair output at 10KHz (at most 50kHz).
2. Use a frequency multiplier to convert the low frequency to IF (like 100MHz to 850MHz). I haven't try this method yet.
My questions are:
1. Is there any modulator in market can help me to get an AM/FM modulated output at IF (like 100MHz to 850MHz).
2. Whether the second idea mentioned above is feasible? If it's feasible, is there any frequency multiplier in market can help me to get an output at IF (like 100MHz to 850MHz) with the input of 10kHz to 50kHz.
Welcome all the suggestions!!
Thank you very much for your advices.
I have two ideas:
My questions are:
