How to control the motor speed in 555 timer pwm?
faraz101
Full Member level 1
Full Member level 1
i have build 555 timer pwm circuit and i am varying the motor speed with the variblre resistor b/w pin 7 and 6.but i want to control the speed form external analog voltages which ranges form 0.80v to 1.20v.
any ideas
thanx
pwm 555
the control pin5 can be used but a amplified version of the 0.8 to 1.2V signal would be needed as far as i know....
i already work on it but it is not giving a wide speed range.coz pin5 already have some voltage about 3v.
thanx 4 reply
555 pwm
you can connect a resistor to ground to reduce the voltage on pin5 .
i worked on it a long time ago and i used a transistor circuit to pull th evoltage at pin5 to ground and it did work well
cheers
555 pwm circuit
pin5 will have a voltage because it is part of a internal voltage divider.... it can be varied externally according to our need....
