How to control output voltage of a 555 timer?
ants
Full Member level 4
Full Member level 4
UK
Is it possible to control the output voltage of a 555 timer?
For example if I supplied 6V I might get 4V output. But what if I wanted an output of just 2V, how would I do that?
Thanks.
The 555 output is a so called "open collector" type, means; you have a resistor to connect for your actual output supply.
Select a working voltage for it properly to your output pulse amplitude needs...
Practically you can attenuate the output signal, or even select smaller/lower supply for the pull up , i.e. through a 2.1V Zener between supply & resistor.
K.
    ants
K., the output of the 555-timer is not OC ..
The output of the 555 comes from a high-current totem-pole stage ..
It can source and sink current (≈ +/-200mA) ..
The simplest way to reduce the voltage is a 2-resistor voltage divider .
Or you can use a potentiometer connected between the output pin and GND (see attached picture), or a resistor followed by a 2V Zener diode, and so on ..
IanP
:D
    ants
I just did it, thanks both, I used a potentiometer.
Oh, Im sorry! I changed it with a U/F converter...
Im apologizing me.
K.
