eepty
Full Member level 2
I would like to make a ultraonic type piezo mist generator which I can control (or change) the output mist rate.
For that I bought a Grove Water Atomizer to test.
I can generate the mist, but the output mist rate is rather low. By checking with an oscilloscope, I know this atomizer is driving 105KHz with about +40V to -20V.
The first question is how can I change the output mist rate? Can I do so by changing the driving voltage?
The second question is I think this atomizer output mist rate is very low, is there another similar module that can output a higher mist rate? Or is there a reference circuit that I can build myself to do so?
Thank you very much.
