abdulmakhdoom
Member level 2
PLease give me a method or circuit for making a tv remote control fan without microcontroller.
You need to design for --
1) IR encoder and IR decoder. Google these terms, you will get lots of ideas.
http://www.rentron.com/remote_control/TINY-IR2.htm
..... He dosnt want to make one....
The IR Encoder and IR Decoder ic's are microcontrollers with firmware..
If you want to use a TV Remote then you need a microcontroller.
You didnt mention what you consider under control of fan. Is it control of fan speed or just On/Off operation?
Meanwhile you can see this circuit for On/Off control:
This looks quite useless.
what does it do .. switch on the fan for 1 second with any detection of IR pulses ??
..By the way, the T2-DEC and T2-ENC, to me, seem like pre-programmed microcontrollers. My guess would be PIC12F629 or PIC12F675. It would be much clearer if you can provide the datasheets of the T2-DEC and T2-ENC.
REMOTE-CONTROLLED FAN REGULATOR
Using this circuit, you can change the speed of the fan from your couch or bed. Infrared receiver module TSOP1738 is used to receive the infrared signal transmitted by remote control.
