hello alexan_e sir,,
wont you think that it would be better if we drive the relays using a driver ic, bcz when I used it once (12V input and 220V(7A) output relay) because of the "no isolation" between the uC and the relay, my controller was getting damaged.. so I used a driver for it like uln2003...
what say sir??
rectify me If i am wrong..
regards..
only one time switching was possible and that too was from high to low i.e. switching off the room supply
if I tried to make it high again then it gets hang...
I never had such a problem, I don't see a way for the mcu to get damaged (unless the transistor is damaged but the base resistor would still protect it), I have only heard of reset problems when switching high loads.
A diode should be connected across the relay coil to protect the transistor.
Alex
Hi Sheldonstv,
What is purpose of diode....is it free wheeling diode application ?....
