joby16 said:Hi,
Use a driver/ Transistor for driving the relay from 89S52. (Eg: ULN2803 , IRF7313 etc)
Connect the Relay coil to the output(collector/ Drain) of the driver and the 12V supply.
Also attach a Free Wheeling diode for relay protection.
Regards,
Joby
H_D_R said:thank you so much IanP.,
can any one please tell me the diference between use of Driver IC and transistor ckt for relay driver except the simple circuit..??
joby16 said:Hi,
It's depends on the Relay Coil Current. The below link may help you to get a basic idea.
http://www.kpsec.freeuk.com/components/relay.htm
Regards,
Joby
Relay coil current = supply voltage /coil resistance
joby16 said:Hi,
The Relay rating (Voltage, Resistance etc) will be mentioned in the Relay itself.
joby16 said:Hi,
At least you should get the operating voltage of the relay ie, 12V DC, 24V DC etc.
Once you identified the input voltage, you can connect the relay to a DC power supply with an ammeter in series and measure the current.
Regards,
Joby
joby16 said:Hi,
observe ur relay once again,PROPERLY, it is written there 12V DC...
got it, or still got problems....
