bobdxcool
Member level 5
![Member level 5](/styles/images/ranks/dlevel5.gif)
I have a gps board which has a gps module. I need to take ttl outputs from the board. But, the problem is the board already has a max 232 ic and the o/p is given to the rs 232 com port.
SO, i brought a max 232 ic board and will connect the rs 232 pin of max 232 to rs 232 of gps board. I need to take rx and tx output from max 232 now to connect it to arduin uno. How do I identify the tx and rx pins on board.
I am posting pictures below.
![2013-02-06 02.12.00.jpg 2013-02-06 02.12.00.jpg](https://www.edaboard.com/data/attachments/28/28623-4d582c25165af6104390e51cb7dce194.jpg)
![2013-02-05 19.07.44.jpg 2013-02-05 19.07.44.jpg](https://www.edaboard.com/data/attachments/28/28606-466dca7c11dccba91522c218209d9892.jpg)
![2013-02-05 19.07.13.jpg 2013-02-05 19.07.13.jpg](https://www.edaboard.com/data/attachments/28/28604-b626b4e883bfad87c65abc671b8e78cb.jpg)
