How to connect copies of a cell in series using Virtuoso?
drabos
Full Member level 6
Full Member level 6
If I have one cell and I want to connect let us say 100 together in series, what is the easiest possibility?
Is there any script to do it?
Thanks
Added after 3 hours 28 minutes:
an other question (but I do not want to make a new topic)...
The situation: I have a cell, I have a parameter in this cell defined as pPar("Parameter"), in the next hierarchy level i also want to use this parameter and just the third hierarchy level (let us say top) I want to give the final value to this parameter.
In the second hierarchy, I also tried to use pPar("Parameter"), but in this case I have not seen the parameter in the top :-(
virtuoso question
You do not need an script for that... you can get it by just doing the following:
1- Create the unit cell in such a way that, if you put two of them side by side, they get connected.
2 - Make a "Copy" and, in the copy pop-up menu, put 99 in the column or row field...
You'll see that it's quite easy and you'll have your 100 cells connected in one second.
    drabos
Re: virtuoso question
Or you can make for example 10 rows in 10 columns to get better visibility.
virtuoso question
If what I understand is right, you're trying to modify a parameter of cell that's two levels of hierarchy bellow... I'm not sure if you'll be able to do it. I never saw something like that. I never needed to do it so I never thought if possible...
virtuoso question
yes, i tried to modify that
virtuoso question
why don't you use subckt.....
