matlab webcam driver
hi there,
i have recently did this case for my thesis on motion detection,
you can use the perpared blocks in simulink,it's easy ,you must use videoinput block and other blocks in the image acquisition group ,but this is possible in matlab r2006 and versions which released after that.also you can use command line for this purpose,following this text i've inserted a simple m code for calculating the difference between two consecutive images.for more informations you can search for the functions used in this m code through the matlab help.
% Create video input object.
vid = videoinput('winvideo')
% Set video input object properties for this application.
% Note that example uses both SET method and dot notation method.
set(vid,'TriggerRepeat',Inf);
vid.FrameGrabInterval = 5;
% Set value of a video source object property.
vid_src = getselectedsource(vid);
set(vid_src,'Tag','motion detection setup');
% Create a figure window.
figure;
% Start acquiring frames.
start(vid)
% Calculate difference image and display it.
while(vid.FramesAcquired<=100) % Stop after 100 frames
data = getdata(vid,2);
diff_im = imadd(data
,:,:,1),-data
,:,:,2));
imshow(diff_im);
end
stop(vid)
