How to connect a printer?
mg0502
It's possible to connect a printer to fpga to print out datas?
i.e. after a data acquisition, sending everything to a printer instead of displaying on monitor.
I've not done it, but this should be simple compared to driving a monitor.
If you stick to a basic printer, that can be connected to an old DOS-based machine and print from that, should be really simple.
Such a printer can just be sent basic control codes and ASCII codes and it will act/print.
The interface need only be an eight-bit output port and a strobe line, or even just a seven-bit+strobe if you don't need the fancy ascii graphics characters.
Then just write a routine to send the required ascii codes out from your captured data.
FoxyRick.
I'm a newbie...
I must connect printer directly to development board.
Do you know if someone has created a vhdl interface?
nowa days the FPGA Kits come with UDB ports.. u can IP cores.. n opencores.org
can use those too..
with regards,
