If you can make sure the switching timing and sequence are correct, then it should be OK. One of the driver might be loaded higher compared to other as two drivers, even both from the same IC, are never 100% identical.kot_b said:But if i remove enable, than setup control inputs. Wait for max transition and setup time, and than set enable high?
