How to configure PIC16F72 with mikroC pro for pic
If it is about How to set configuration bits of 16f72, Make a new project with 16f72 then you can go to Project->Edit project window. If it is about a module for a specific task, You have to select proper library and set configuration variables.
Thank you,
Thank you,
Hi DineshSL,
Happy New Bengali year, Would you send some example like, LCD,ADC,keypad,timer overflow interrupt etc. using PIC16F72
Thanks & Regards
This is Power Electronics forum...
the appropriate forum for this post is the microcontroller forum....
If you read your Microc Help Manual you will find code examples of LCD,ADC,keypad,timer overflow interrupt etc
Thanks for suggetions. All code in manual based on pic16f877 thats are not working on pic16f72.
thanks & regards
That is not totally correct. Both PIC are PIC16 and use the same coding. You can in most cases adapt the 877 code for the 72.
