how to configure cadence 5141 on RHEL 3 AS
asueee0
Full Member level 1
I just installed ic 5141 on RHEL 3 AS, but do not know how to configure to get it run (I need icfb& only), could any one provide detail and specific instructions, I installed cadence in: /usr/cadence. Thanks.
hello,to let the icfb& work well, you need firstly to set the license for the cadence(if you have the license file).Secondly you need set the path for the software.
you can search the materials in this forum.
also the following two links this helpfu for your work!
